2000 KTM EXC 300 - Odometer Drive Side Hub Seal Question
I am replacing wheel bearings and seals on a 2000 KTM 300 EXC front wheel for a friend.
Bearings are re-installed and seal on disk brake side is installed.
But I'm looking at the odometer drive side seal, (the larger one with the metal outer ring...
and would like to know if the open side of the seal is installed inward or outward.
I'm figuring inward, but wanted to make sure before I install it...
It is a very tight fit and the previous seal had come apart, so I have no reference to work from...
Any one with experience here?
The bearings and seal parts vendors have nothing of value that I have found scouring their websites.
And the KTM microfiche doesn't provide enough detail either.
Appreciate any assistance you might provide.
Thanks!
