05 rm 125 mpg
To whom it may concern
33.358233 MPG (my tracks GPS smartphone app)
My speedo is slightly off According to my GPS. Must recalibrate
.02606112 ounces per mile
Stock pipe
Pro Circuit type 296 silencer
370 main
37.5 pilot
2nd clip
Woods and trail riding.
80 to 85 degrees f
Fairly humid
+ or - an oz or two (closer to 1oz)
depending on how hard you ride. because that's 67 mpg to a tank, I go threw at tank in an hour, which equals about 30 miles
Woods and trail, Not motocross
I'm sure many circumstances would change that number, even if slight change in the air screw. I was just stating my FACTS for my terrain. It's important for me to know. Can I go forward another 3 miles or must I return?
Nick, Your MPG is unclear. All you know is, hay I'm Out of gas or hey there's some gas left. No offense. I don't know, but I bet different MX tracks would produce different mpg's even with the same bike and set up. I even think my specs might slightly change with temperature and humidity changes. Regardless, it is information I need and now I have a basepoint.
113.41799 miles with a IMS 3.4 Gallon tank. I also installed a Kdx Reserve petcock on both my tanks. My IMS tank also has its own hardware and radiator shrouds. Gotta love ebay. Makes for an easy swap because I loctite the hardware.
Francis
gps miles aren't real accurate in trails that wind and turn, you likely went a bit farther?
Yup, GPS works great in a straight line for calculating or verifying mph, throw in some curves and a few switch backs and it's distance function is only good enough to be "pretty close" but nothing more.
And as always "your mileage may vary".
with an actual gps device you can set your track points closer together for more accuracy in the woods , "most often" on my 2 Garmins. The OP said he was using his phone app, not sure how often they calculate? or even can be adjusted?
error in odo's, guess that's why they have resets in enduro's , LOL
Edited by highmarker
Wow! I have found that our RM125 gets only slightly better mileage than our RM250. Both are set up for, and ridden in tight woods.
250: 15-20 MPG
125: 20- maybe 25
