Fork and suspension set up
Hi guys
On my last ride after a 55 mph nose dive I have blow fork seals and before I just replace the seals and the oil I was wondering what set up you run and rear suspension setup
Thanks
If your forks are leaking because you crashed, this has nothing to do with fork seals, you probably scratched your forks
The 250 fork bushings have a habit of wearing out sooner than most. If the bushings are worn, new seals will not help. Take the forks apart and inspect the bushings, if the coating is getting thin or has worn through in spots, replace them.
