01 250 wr handle bar risers
If I add 30mm risers to the bike. Will all the cables still reach? To me it looks too short. But I guess it can be deceiving. I was looking at the tusk risers which are 1.2 inches taller.
Usually you need to buy a longer throttle cable from motion pro or similar. You may also need a longer front brake line but that would depend on how much slack you have now.
30mm riser that is over an inch are You sure they are 30mm
I put 15 or 16mm (don't remember which) on my 06wr250 there were no problems at all
that is with stock handler bar that is a factor that will affect cable lengths skinnier or wider bars
I love them when I stand up I am I not leaning over the bars
I have a GPR mounted under the bars,with 30mm risers.Original cables will be fine.
Edited by rushdog
