Rear wheel collar problem
First guess is to say that the bearings are not set deep enough. You need to install them until the sit tight on the lip inside the hub. Any way you could send us a pic?
Check ID, OD and width against old bearings. If the match Probly not seated all the way
Got a question, I just bought new rear wheel bearings for my 2003 yz85. Got the old ones out and one new bearing in but when I go to slide the collar back into the hub, it is now to long and preventing me from getting the other bearing back in.. I'm stumped.. Anybody got any clue why this is happening? The bearings are the correct ones to, and I have the gaskets on the outsides of the bearings.
