carb problems? motor running rough
hello all,
I have recently purchased a 1999 kx250.
The previous owner had it since new and pulled the motor out to run in his go kart. IF hes telling the truth, the motors done only 40-50 hours and the frame 10-ish. It has a FMF Fatty chamber and FMF Muffler, weighted flywheel, VForce 3 Reeds, 52 tooth rear sprocket, new piston and rings and new clutch.
i took it for a first run last weekend and when the throttle is open, it goes hard but when on a hill descent with no throttle, the engine feels like it wants to still push me forward in a 'pulsing' type fashion like its getting drips of fuel. When its hot its idle is also very pulsed, not a smooth purr like i thought it should be.
also the bottom end feels alot less than i remember when ive previously ridden an 07 kx250 and also a 05 cr250.
can anyone help with any ideas or solutions?
hello all,
Sounds like maybe the pilot circuit is clogged or needs to be rejetted? I'm sure the carb could use a good cleaning anyways. The main jet controls 3/4 - full throttle which sounds like its acting OK, but the pilot jet controls idle to 1/4 throttle so this is where it sounds like your having issues. I'd clean out the carb, make sure your air filter is new/clean, and see what happens.
Adjust your air screw in.
i have returned all of my settings to stock - middle clip, std jets main and pilot, 1.5 turns on air screw and gave everything a good blow out
still having same issues? (maybe a little worse)
still unsure what to do. have read that a surging idle is a lean condition?
