ktm sx from 125 to 150cc
hi there im intrested to convert my 125sx to a 150sx
i know that i basically need a piston,cylinder,head and cranshaft with rod...
so the cost is not tinny...
im thinking to save some money with using a 125 cylinder bored and replated
can this been done? im thinking i spend half of the money of an new cylinder...
is that possible?
tye1138  a friend just picked on a nice 07 125.  He too is looking to convert it to a 144 when its due for a top end.  What years are candidates for the bolt on 144 kit?  He understands he'll need the complete top end, including cylinder, power valve, piston, rings, head, etc.  I just want to confirm that his 07 is a good candidate to upgrade.
thanks
Edited by eprovenzano
The bottom end hasn't had much change since 2003, so it really doesn't make a difference which year since you will be replacing the crank, cylinder, piston, head, etc.
The best parts to get for the 144cc upgrade are the 2010+ components. It seems KTM hasn't made very many MAJOR changes since that motor. So when I did my upgrade, I bought a 2009 cylinder (which hadn't been changed) and a 2010 head/crank. The pistons have gone through many revisions, but the Vertex is by far the way to go.
The last thing you'll need is a 150SX cdi. I found it makes a HUGE difference in the power delivery. I tried to get by with a 07 144 CDI and it didn't work, neither did my 07 125 CDI. So I actually splurged and bought a new one. To my utter surprise, the 2010 150SX CDI I bought made a HUGE difference and I haven't looked back. Mind you... I was running a 144SX 39mm carb, so perhaps with the stock 125 38mm carb, things are different? I know the jetting is totally different between the two carbs.
Anyway, I personally wouldn't bother upgrading a motor unless it already needs a lot of work. Its far cheaper to buy a used 150SX motor and get the CDI as well...
Ohh and the 144cc machines seem to love the FMF 125 resonator with short silencer. Go figure!
so i need the same parts for a 150 or 200 conversion?
i was willing to do a 150 conversion cause i did'nt wat to spend alot of money for a 200 upgrade...
but i see that both conversions are about the same...
ether for a 150 or a 200 conversion  need about the same parts...
piston,cylinder,crankshaft assembly,rejeting and a cdi
so if the parts of the 150 and 200 cost the same(whitch they dosent)the upgrade costs the same money
right?
I think there is an easier way of doing it. I know KTM had an upgrade kit for the 125 and I'm not sure if it included a crank/rod. You'll have to wait and see if one of the 200 experts posts on here.
i said that because if you have the budjet you can go 150 or 200cc with the same money
i want to make mine 150cc because i want to trailride not doing only mx...
