to reed or not reed!
gonna change the reeds and im wondering if getting a vforce 3 cage is gonna make a noticeable performance gain, OR if I should just get pro series reeds that go into my stock cage...
ALSO I saw something about a RAD valve that boyesen makes but I couldn't find it on rockymountainatv?
anyone have ideas on what the difference is between the RAD and vforce 3 cages and maybe even opinions on which is better?
Personally I have been disappointed with the results that V-Force systems have given me. I have tried them on 4 different bikes and it didn't make a huge difference on any of them. I have been really impressed with the gains that Boyesen's RAD valve has given on every bike I have tried one on. If you don't want to spend that much money, I have found that you can still get a little better performance for very little money by running some of Boyesen's dual stage reeds on the stock cage.
  • Like 2
+1 on Boyesen.
Also a regular check of the reeds for edge fraying and/or not laying flat against the cage is a good idea.  If the reeds don't lay flat you can turn them over for a few more hours of life.
  • Like 2
Like everyone else tells you, get Boyesen... They have been around forever, and seem like a MUCH more quality product than VForce 3. The reason I purchased the RAD valve from Boyesen was that my plastic VForce 3 reed cage "broke", and wouldn't hold the reeds snug.
I have the vf3. I live right down from boyesen. Very smart company and they support this site. Wish I had a rad valve. The boyesen replacement reeds are great too. Affordable replacement and you choose what tension you want for different power characteristic. A stiff fiberglass reed will give more top. A fiberglass and carbon combo gives a good compromise. The carbon reeds will flex more and give more bottom and throttle response. Reeds are a minimal change. Moving the cage in,out or angled makes a bigger difference. Also you can modify the reed stop to change power.
what year rm? 04 and beyond are dialed in with the oem reeds. I bought a set of v-force III , ran it for a short time and really didn't feel any noticeable difference. I ended up selling the v-force and running the oem cage. Like stated above, keep the reeds fresh. Boyeson sells a pro series set (carbon fiber)that is very similar to oem.
For that matter, the oem pipe is pretty good too...
