Any ideas for weight reduction on an old dr200?
I know there's probably not much but it's quiet and good fun to lug around the backyard just wondering if anyone knows how I can cut down the weight a little?
Replace the battery and e-start with a kick starter
Replace muffler with aftermarket
Replace solid-end handlebar with aluminum aftermarket
Replace rear fender with cheap, lightweight aftermarket
Replace tail light assembly with LED aftermarket
Replace head light assembly with a cheap, universal aftermarket
Replace the gas tank with a thin plastic aftermarket (from an MX bike)
Cut off passenger foot peg
Remove hand grab frame behind the seat
Remove turn signal if not required by your State
Remove kick stand and cut off its bracket
Less 30 pounds.
I'm pretty sure this can be done, because the predecessor to the DR200 is the SP. Both bikes look identical. Same frame and same engine. Only difference is accessories. The SP weighs 225 dry. The DR weighs 250 dry. So you can easily drop 25 pounds by removing accessories. I think the heaviest accessory is the battery and e-start.
Edited by Terminatr
