need a throttle cable with 2 pulls, not push pull
I bought a carb that requires two cables, both pull. The only one I've found with a Y split at the end is for a pw80 which will most likely be too short. This is for a crf150f
any ideas on where to look or what to type? I'm gettn nuttn. Thanks
Any carburetor should have the accompanying throttle cable available.  CRF150 carb--CRF150 throttle cable.  If you install a different carb onto the 150, then you maybe SOL for finding a throtle cable that's long enough.
Stating what parent bike the donor carb is off of might help too.
You might end up having to get someone like Motion Pro make a set of cables for you.  Should not be a big ordeal.
Edited by wvdualsport
A late 70's Honda twin street bike should take care of that...they're everywhere.
you my friend, are a savior
Like he said; A lot of older (70s) twin cylinder British and others, used throttles that had two cables. One cable for each carb.
Two stroke singles on bikes of that era also used Y cables. They split off to the carb and the oil injection pump.
(Kawasaki, Suzuki and Yamaha)
