2013 450r won't start
Hey guys. I volunteered to help a friend out with his 2013 crf450r. He tried to start it the other day and it won't run. It ran Great until the other day he was riding around and it completely bogged down so bad it could be recovered from. It doesn't feel quite rite when your kicking it either. I checked plug, carb, pump. Any help would be greatly appreciated.
No carb on that bike, it uses a throttle body EFI system. How did you check the TB? How did you check the pump?
I would start with a good tank-off washing of the motor, then remove the valve cover and check valve clearances and cam timing while you're in there.
Edited by Eddie8v
No carb on that bike, it uses a throttle body EFI system. How did you check the TB? How did you check the pump?I would start with a good tank-off washing of the motor, then remove the valve cover and check valve clearances and cam timing while you're in there.
Ok. He's doing it right now.
