Air fork equalizer thing? 2013 KX 450 air forks
I checked these guys out after seeing them on facebook, actually kinda cool looking. I guess its only one valve to check the pressure and stuff. it helped me because I was really annoyed when I had to recheck my pressure and it took so long, this made it easier. thought you kawi air fork guys would find this useful.
http://www.airprofork.com/c/19/air-fork
I have a similar one and they are awesome got mine off CRFSTUFFS.com
yeah I have seen those, I just thought the airpro was better because theyre only a few hours away from me... but no doubt they make the airpressure checking a hell of a lot easier!
So for us still running springs in your forks, could someone educate me on this topic. what is the theory behind connecting both together?
could cause 1 seal leak to leak all your air out if your bike . But checking the air is a 30 second task now and not 5 minutes.
Wow that looks like a great set up... Bit exspensive tho..!! So does it give u a combined pressure reading?
Yeah it does, mine is connected to one valve that both forks put air into. So you always have equal pressure and it's super easy to check
