Air leaking from under valve washer
I noticed my front tire was flat from just going down the road and back and even when I put more air in it, it still is flat by the time I ride for maybe 2-3 minuets down the road and back. I noticed it was leaking from under the washer when I sprayed some windex on it, I noticed when I loosten the bolt to keep the valve from pushing in the air seemed to slow down then when I had it tight. Any ideas?
Sounds like you need a new tube and then make sure the rim lock is tight. (Or if its missing, install one)
Did you ever get the front wheel off?
no...
