Throttle Cable for Carb Upgrade TTR to kx65
I am doing a carburetor upgrade on my ttr 125 to a kx65 carb and just need to know if I can take my stock cable off of my stock carburetor and use it. I do have the boot cover on top of the kx65 carb but that is it. Would this be the easiest way to do it, I was hoping I can just unhook from the old carb and slide it into the new carb with little effort.
This is not recommended by any means, a kx65 is a 2 stroke so the carb is designed to take in mixed oil and has ratio, not just plain fuel. The performance of your ttr will either be the same or worse. If you want more performance, buy an actual motocross bike and not a trail bike.
