KTM SX-F 2011 - Wont Start... FI Light Flashes?
Hi,
So my Brothers KTM SX-F 350 2011 wont start, it turns over on the battery but the engine wont start... we have tried everything we can think of... cleaned injector... changed all filters... cleaned fuel pump... Etc...
The FI light flashes once and then stays on for about a second... so its one short then one long flash... Anyone know what this is as neither of us have a manual and it says what each combination of flashes mean in it also i cant find anything online...
Thanks for reading my question
I'm looking in my manual and that code doesn't appear. The codes in the manual are 2,6,9,12,13,15,33,37 and 41 that are listed. Did the issue just start? I would at least start checking all the connectors and wiring connections. Make sure that they are all tight and clean.....no pun intended.....
I had a similar problem and it was the fuel pump relay, the one behind the side panel near the silencer, does the bike make a noise from the fuel pump as well, mine made the noise over and over
