Need an hour meter
I don't have any experience with these but I get the impression that the Works Connection is better than the Hard Line. Can anyone comment that has some experience?
I have recently bought a sendec and it has a tachometer included. You do not need a battery to run it. Seems pretty rhobust.
I liked it.
My trailtech Vector has hours, clock, speedo, oil temp (not easy to implement) as well as trip odo and hours (in motion and total). Would this be a better all in one solution? Ambient temperature too. Here is one for $77.
+1. That's what I use. Not as accurate as a dedicated hour meter but it's plenty close enough to gauge maint intervals.
+1 on trail tech,
they also make a dedicated hour meter for about $35
I didn't know that trail tech made just an hour meter. I'll check that out.
I have bought two hour meters off of eBay.
One has 28 hours on it and the other one has 67 hours.
The cost of each was less than $12.
These are just hour meters and have no reset or tach.
Simple Hours meters are pretty cheap on eBay.
I have an Hour Meter / Tachometer on my KTM.
The newest design just works off vibrations.   No wire needed.
If you want more guages, The Trail Tech seems to be the way to go.
