Drz 400 sm grinding noise
Hi Guys my drz 400 sm 2007 has a grinding noise while in gear and the clutch is in, can hear & feel the friction badly when the bike is off and pushing it in 1st gear with the clutch in. also the bike wont start, it does have spark and compression, just back fires when push starting, Please help. Thanks
Have you taken the cover off to look at it and check for anything? Have you done the loctight mods?
Sounds like your stator bolts back out on you.
Don't try to start it , remove the left hand side engine cover first . Check the bolts .
Remove the right hand side crank case cover , check the primary nut and counter balancer nut .
Have a look at the FAQ at the Top of the page
Edited by backyard hack
