10 FE450 Smoke
Hey all,
So I changed mufflers on my 2010 FE450 from the factory krimzon to an fmf ti4. I have noticed that it smokes on start-up, and after riding there will be a nice layer of soot on the tip of the muffler. Any ideas?
I know that its not burning oil because that would be blue smoke...but this smoke is more black, which suggests un-burnt fuel. I am running high octane fuel.
Would putting an iridium spark plug in help?
Thanks
I had similar symptoms.  Turned out to be a leaking exhaust valve stem seal.
Ok thanks!
I can relax know that I know its not too serious.
Might be a leaky injector. There FI system stays under pressure when shut off, so some fuel might leak out over time if the injector is leaking.
