Starter button and horn button broken!
I took apart the starter button and it is clean in there.  Then I discovered my horn also doesn't work!  They were both starting to wane on me over the past few weeks, they would work about 25% of the time, now neither will work at all.
The speedo displays well, the battery hookups are secure and the battery fuse is intact.
What am I looking for?
Get out the volt/ohm meter and start testing.  It is the only way I know.
someone dropped the bike in a creek, or sprayed wd-40 in the buttons ?
(that's how I killed mine)
I had trouble with the small printed circut board behind the start button breaking. Cause intermittent starting contact. Fixed it with JB weld. Might be the same for the horn button????
