xr650r clutch drag Q.
my xr runs pretty damn good i cant complain... but i noticed that is has clutch drag? if that is what im experiencing...  if i put it in first gear and lift the rear wheel it will start spinning pretty darn quick. but i dont have trouble finding neutral while running... is this normal? the clutch pull and operation feels good ...
nah, not normal. You can probably feel pull while sitting at a light.
you have 2 points of adjustment.......at the clutch lever and down next to the motor on the left side. Wind the upper adjuster all the way in and adjust the lower. Then if you want to tweak it out you can just screw the upper adjuster a couple turns.
thanks, i will start tampering with that then !
