changing a spark plug on 2012 te250
i know it sounds stupid but i cannot get the plug off or even the spark plug wire off because the frame rail is 3/4 of an inch above the top of the spark plug wire? anyone know a trick/way to do this
You may have the taller plug. There is a plug for these bikes that has a shorter top. It makes it a bunch easer but its still not very easy. I went back to a iridium plug, BR8EIX in a NGK. I think iridium plugs last longer but it is taller. I had problems with both sizes with the tank on so I just went with IMO the better plug.
To answer your question you just bend the rubber plug over and wiggle it out.  :thumbsup:
Edited by i4bikes
