01 TE 570 jetting Q
hi all,
Been off of my bike and TTicon1.png for a while.  Have an 01 570 and doing a rebuild of carb.  The problems are many after sitting for two years.  I have had it running but not well the last few weeks thus the rebuild.
Here are my jet sizes;
Starting jet - 60
idle jet - 57
main jet - 162
needle jet - AB264
needle valve - 300
needle - K32
Riding in Nevada approx. 4600' elevation.
The body is getting a full sonic bath tomorrow and fresh screens and gaskets all the way around.  The bikeicon1.png was flat on full throttle on the last few rides after a local mechanic "tuned" the carb to try to resolve the performance issues.
I am prepared to adjust/jet until it is runninglb_icon1.png perfect so I am looking for some experience and a starting point.
Lastly a big shot out to the guys I rode with in Baja a few years ago, Steny, George, his boy and all the others.
here are my thoughts...pilot jet too big for that elevation.float valve due for a change out unless recently done.the k32 needle may be worn,the ab 264 needle jet may also be worn.is your manifold cracking?is your flywheel magnets coming apart?dan
Hi,
 are you 100% sure you are getting enough fuel to the carb,
 the 570 / 610 need LOTS of fuel at high rev's,
Charlie
The carb body is getting a sonic bath today and some glassing to get some crud out of the bowl. Replacing most of the parts that can wear I.e. needle and jets.
I haven't opened the case to inspect the flywheel. The clutch is tight and works well. I am replacing the floats. I received an education on the importance of floats and float setting this morning.
I'll replace the parts mentioned Charlie. Thanks guys. A couple of the o rings were shot and the guy who worked on it last sealed the throttle cable cap with gasket maker.
Soon as its done I'll post some pics.
Tam
Ok I had the body, banjo, choke body, bowl and bowl nut ultrasonically cleaned.  I took it to a local carb guy Competition Carburetor.  He builds race carburetors and ships all over the country.  He used a cav tank.  The results were amazing.
Got a Delorto carb kit from Bevel Ducati in Concord Ca.
After cleaning everything and rebuilding the results.......AMAZING.  Bike kicked over first time!  After some tuning I headed up the mountain.  WOW.
http://i1176.photobucket.com/albums/x336/rangerreeve/PHM%2040%20Rebuild/IMG_4278.jpg?t=1378075946
http://i1176.photobucket.com/albums/x336/rangerreeve/PHM%2040%20Rebuild/da6470e0-452f-4ba0-ab22-3d4aa1145e85.jpg?t=1378075420
http://i1176.photobucket.com/albums/x336/rangerreeve/PHM%2040%20Rebuild/20130901_145742.jpg?t=1378074973
norman foley has always said as long as it's clean a dellorto IS the best carb on a left kicker,
your bike looks great ! well worth the effort ; . }  never seen a steering damper on a left kicker before..!!,
 Charlie
Where did you get your carb components from?
