PW50 leaking fuel from carb
I have a pw50 (1995 I believe) that is leaking fuel at a very fast rate out of the circled outlet on the carb. I believe this is the bowl overflow.
I checked that the float is not jammed, and the carb itself is quite clean.
What else could I check to see what's causing this?
thanks!
