2003 yz 125 front forks?
What can I do to improve or what could I replace them with? I've got about 600 to put into the forks or to buy some other ones.
Late model 06 up kayaba sss forks. You will have to change clamps. Only way to get rid of the mid stroke harshness
06 triple clamp will fit on 03 fine?
I think so. If I remember the 03 forks are 46mm, 05+ are 48mm. Im almost sure it's a direct swap. You may have to change calipers depending what year of forks you get
