Motorcross Platnum YT7B-BS
My Yuasa battery died. My wife surprised me by getting me a replacement from our local battery store. It's a Motorcross Platnum, and it was $65. Before I install it I wanted to know if it has the same CCA rating as the Yuasa, but cannot find that particular rating on the Motorcross brand website. Does anyone have any experience with this replacement battery? In my opinion the Yuasa barely has the power required for the DRZ, I don't want a battery with less power.
Any info is appreciated,
Mike -
Mike -
I would imagine it would be in the specs on the box or the battery itself, otherwise I would be a little dubious about using it.
Original Yuasa battery was rated 85 CCA.  Current replacements are are rated 120 CCA since about 2010.  Is there really a difference or just a revised method of rating the battery?? Wish I knew.
I suspect your Motocross Platinum will be 85 CCA same as your old Yuasa.
I'm currently using a 120 CCA LynVick.  I can't tell the difference from any other battery Yuasa or other cheepo.
Thank your wife and instal the battery.
My pointless two cents... If my wife, gf, or any woman was awesome enough to bring a battery for my drz, I'd just be stoked about it.
I got 3.5 years use out of my stock battery and that was with being stupid leaving the key on a few times.
Yes, she is pretty awesome. I got about 6+ years from my Yuasa, so no complaints.
Mike -
When you do the vehicle search on that link, it brings up your battery and the specs which are the same as the Yuasa.
Battery Search
Vehicle Type             Select a Vehicle Type                         Motorcycle                         ATV (All Terrain Vehicle)                         Scooter                         Utility Vehicle                         Personal Watercraft                         Snowmobile                         Riding Mower                         Japanese Tractor / Generator
Search by Battery Type
                Select a Battery Type          12N10-3A-212N11-3A-112N12A-4A-112N14-3A12N24-3 (26A19L)12N5-3B12N5-4B12N5.5-3B12N5.5-4A12N5.5A-3B12N7-3B12N7-4A12N7D-3B12N9-3A12N9-3B12N9-4B-15181451913530306N11-2D6N11A-1B6N12A-2C (see also 6N12A-2D)6N12A-2D6N2-2A6N2-2A-36N2-2A-46N2A-2C6N2A-2C-16N2A-2C-36N4-2A6N4-2A-36N4-2A-46N4-2A-56N4-2A-6 (see also 6N4-2A-8)6N4-2A-86N4A-4D6N4B-2A6N4B-2A-36N4B-2A-56N4C-1B6N5.5-1D6N5.5-1D-1 (disc. use modified 6N5.5-1D)6N6-1B6N6-1D6N6-1D-26N6-3B6N6-3B-16YB11-2D6YB8L-BB38-6AB39-6B54-6GYZ20HGYZ20HLGYZ20LHYB16A-ABKMX14-BSSY50-N18L-ATSYB14L-A2SYB14L-B2 (disc. use YB14L-B2)SYB16L-B (disc. use YB16L-B)Y50-N18A-AY50-N18L-AY50-N18L-A-CXY50-N18L-A3Y60-N24-AYB10A-A2YB10L-A2YB10L-BYB10L-B2YB12A-AYB12A-A W/SYB12A-A W/TAYB12A-BYB12AL-AYB12AL-A2YB12B-B2YB12C-AYB14-A2YB14-B2YB14A-A1YB14A-A2YB14L-A1YB14L-A2YB14L-A2 W/SYB14L-B2YB16-BYB16-B-CXYB16AL-A2YB16B-AYB16B-A1YB16C-BYB16CL-BYB16HL-A-CXYB16L-BYB18-AYB18L-AYB2.5L-CYB2.5L-C-1YB30CL-BYB30L-BYB3L-AYB3L-BYB4L-AYB4L-BYB5L-BYB7-AYB7B-BYB7C-AYB7L-BYB9-BYB9A-AYB9L-A2YB9L-BYHD-12HYIX30LYIX30L-BSYT12A-BSYT12B-BSYT14B-4 (YT14B-BS)YT14B-BSYT4B-BSYT4L-BSYT5L-BSYT7B-BSYT9B-4 (YT9B-BS)YT9B-BSYTR4A-BSYTR9-BSYTX12 (Factory Activated)YTX12-BSYTX14 (factory activated)YTX14-BSYTX14AH-BSYTX14AHL-BSYTX14HYTX14H-BSYTX14LYTX14L-BSYTX15L (Factory Activated)YTX15L-BSYTX16-BSYTX16-BS-1YTX20-BSYTX20CH-BSYTX20H-BSYTX20HLYTX20HL-BSYTX20HL-BS-PWYTX20LYTX20L-BSYTX24HLYTX24HL-BSYTX4L-BSYTX5L-BSYTX7A-BSYTX7L-BSYTX9 (factory activated)YTX9-BSYTZ10SYTZ12SYTZ14SYTZ5SYTZ7S
Suzuki » DR-Z400, E, S » 2009
Battery Family: Maintenance Free
Battery Type: YT7B-BS
Voltage: 12
Capacity: 6.5
Dimensions: 6" X 2 5625" X 3.6875"
Weight: 5 .lbs
Metric Dimensions: 150mm X 65mm X 93mm
Metric Weight: 2.3 kg
Acid Volume: 0.33
Amps: 0.7
C.C.A: 120
Edited by Black_DRZ
Oh, thanks for doing that for me.  :thumbsup:
I appreciate the info!
Mike -
