Tranny case comparability
Hi all, I had my 06 tc510 kick back while starting and it must have hit the
Gear behind the clutch and it absolutely destroyed both the right inner case and the clutch cover/outer case. Per Dan@ motoxotica can only order both inner cases as a set ($1100). I haven't been able to locate any 2006 parts and was wondering if anybody knew if the 05 cases are compatible with the 06. If I'm not mistaken it can also be a 450 case as they are the same engine minus a few mm's in stroke. I'd certainly appreciate any info or to be pointed in the right direction. Thanks!!
look up the P/Ns in the parts catalogs to see if they are the same. fit and finish wise I believe that they are same, but the newer case may have some strength mods (I have no idea just a guess). But again machine point dimension wise they should be the same.
hi,
do a search as these were a reasonably common failure back in the day..!!,
 also have you tried "fuji's factory" on ebay - husky breaker specialist,
 Charlie
Thanks for the reply fellas!....I will try the ebay search for sure. I have it tore down and thankfully none of the gears or kickstart assembly was damaged.
