I want to upgrade my Honda clone from 70cc to 110cc
I have a custom moped I built with a 70cc Loncin 4 stroke Honda clone engine and I also have a Loncin 4 stroke 110cc Honda clone engine laying around.. I just discovered there is a hole in the valve cover on the 70cc so my question is, can I either put the 110cc valve cover on the 70cc or what I would really like to do is put the 110cc head on the 70cc engine..
So is it possible to put the 110cc head on the 70cc engine?
I know I'll have to change the piston and possibly the rod but is it possible to do the head swap in the first place and if so what all do I need to do?..
You will spend just as much on a big bore kit and a head as you would on a complete 110 motor. Just buy the motor and bolt it in.
I already have the 110cc head though, The engine that is on the bike is a 70cc Honda clone and I have a good 110cc Honda clone engine, but the 110 has a clutch and the 70cc doesn't so I want to use the 110cc head on my 70cc block.. Can I do this? If I can what all do I have to use out of the 110cc engine?
So far I know I have to use;
-The 110cc piston & rings.
-Carburator off the 110cc engine.
-Head, of course.
-110cc CDI.
Do I use the 110cc piston rod and crankshaft?
