PC link arm on a 2013
just saw pro circuit make a 1mm longer link for the 13
has anybody here tried one of these out?
heres the write up on them.
Linkage Arm Description:
Pro Circuit's Linkage Arms are CNC-machined from billet aluminum and are designed to stiffen up the initial linkage curve and lower the chassis, making the bike much more stable. This will also help eliminate the initial loose and wallowy feel. Turning and cornering capabilities are greatly improved as well. Although having your suspension revalved by Pro Circuit would make a considerable improvement, the Linkage Arms alone provide a major improvement over the stock set-up. Each link arm includes all of the required bearings and seals.
Stock Length for the CRF450R ('13-14) is 143 mm - Pro Circuit Length is 144 mm
Edited by tjmunro
