Rough Idle, Hesitation/sputtering at low throttle
I just bought an '04 DR-Z400S, it runs like a bat out of hell and I have been having a blast ripping around fire trails where I live in the Panhandle of Florida.  There are a few issues that I think are all just carb setting/jetting issues.  Any help or input is welcome.
Problems:
1. The bike idles rough.  Pretty sure it actually misses combustion every now and then at idle.  If left alone, it will sometimes stall.
2.  When I'm cruising at the low end of the rpm range, maybe 1/4 throttle, the bike will hesitate and surge.  It's been hot and humid here, as usual.
3. When I let off the throttle and clutch when I am coming to a stop, occasionally the engine will cut out.
4.  Sometimes when I clutch and let off the throttle, or even put it in neutral the engine won't come all the way down to idle.
Setup:
Stock exhaust
3x3 mod
Keihin FCR (pretty sure it's the 39mm)
If there are other mods, I'm not yet aware of them.  I don't know how it's jetted.
Thanks!
When you say clean the carb, do you mean rebuild and thoroughly clean, or use something like b-12?
Probably best to disassemble the carb, then clean out all of the jets and passages with carb cleaner (or similar product) and some compressed air.
Might not be a bad idea to check and record jet sizes and needle position while your in there.
Thanks!  I'll give it a go.  I haven't even taken the tank off of this thing yet.  I guess it's a good thing I haven't made any plans for Labor Day Weekend!
Do I need a rebuild kit, or will I be able to put it all back together without new parts (assuming nothing is broken/in need of replacement).
Having a stock exhaust and a/b mod with a FCR on it is going to be problematic. To much carb and not enough outflow. It is very wise to look into the carbs jetting and know where it is at. Suggest you go back to a stock carb if you choose to stay with the stock exhaust. It will be a better balance to the engine. The best way would be to buy a freer flowing exhaust. Best is the MRDssw for the price. It can support even big bores well.
Do not take apart the part of the carb that has security screws ! The rest you can clean as you will. Just remember everything and take notes for all jetting and for reassembly.
No need for a rebuild kit, just clean it thoroughly and replace anything if need be. Also like burncycle said take your time disassembling the carb and take notes and/or pictures. Have a clean workspace to keep your parts/hardware in order, because it is easy to lose some little parts.
Taking the tank off is easy, getting the carb out/in is the hard part. Removing the top subframe bolts and loosening the bottom subframe bolts and moving the subframe a little will give you an extra 1/4" or so and makes it easier.
I'm running the FCR-MX with the air box mod and stock exhaust.  I noticed much better throttle response and a little bit more up top, it works very well when jetted correctly.  Though I do agree with you, the SSW/MRD you will see more gains up top than I have with the stock exhaust.
Thanks y'all!  Glad I don't need to shell out and then wait for a rebuild kit to ship.
It's my intention to get at least a slip on exhaust eventually, but like most of us, cash flow is the main thing keeping me from doing ALL THE MODS.  Honestly, right now, this thing feels a lot happier when I'm ripping on it than when I'm trying to baby it down the quiet 15mph street I live on or cruise at 35 mph.
Burncycle, I wish I knew where the stock carb is.  The guy I bought the bike from never mentioned it had any mods(I'm not even sure he knew it was modded at all), and it's my first dr-z, so i didn't really know where to start looking.
I'm probably gonna start tearing this thing apart tomorrow morning.  I'm sure I'll have loads of questions then.  Thanks for all the advice!
Ok, last weekend I checked the valve clearance(were within spec), changed the oil and filter, cleaned and oiled the air filter, and cleaned and reinstalled the carb. Been pretty busy all week, but just had a chance to mess with the bike some.  Now, when I start the bike, it runs fine in choke, but as soon as I take it off choke, it dies.  Fuel screw is set to 2 turns out.  Any ideas?
Welp.  Seems like my issue yesterday may have just been that I had the idle speed adjuster set too low.  This afternoon I took the carb out again, cleaned the bowl and jets, with special attention to the pilot.  I put it back in, and had the same problem.  When I tried turning the idle speed adjuster up, the bike idled like normal.  It's still a little rough, but I think that's because my mix is off.  I ordered a zip ty fuel screw yesterday, so I'll see if getting that dialed in will smooth out the idle/hesitation issue.
Problems:
Setup:
Stock exhaust
3x3 mod
Thanks!
List your current jetting
I'd suggest removing the spring on the coast enricher - i had exactly the same problems you describe and it all went away. It's so easy to do anyway, you can put it back if nothing happens.
If it is the E model Fcr it will have a CE, ....Coast Enrichener removal is the way to go....
Pilot Jet: 45
Pilot Air Jet: 65
Main Jet: 152
Where is the coast enrichment spring, and how do I know if I have an E model FCR?  I know I have an E model intake boot, because it doesn't have a fitting for the crankcase breather hose.
Mine is an S , has a Mikuni and it also has an enricher.
Right under the sensor plug, remove the screws while holding the cover down or it will fly off, because the spring is strong.
There are many suggested things you can do as to plugging vacuum intakes, etc, but as all i wanted to do was a quick test,
i simply removed the spring and left the diaphragm there as a seal (closing it back can be tricky because you no longer
have the spring to hold the diaphragm in place, watch out for those small guide holes). I am so happy with the result that i'm letting sleeping dogs lie for the moment, i'll look into all that plugging and o ring stuff later. One really has to wonder what was Mikuni thinking. Funny thing is, apart from all the problems it created, it also didn't do anything for the one thing it was meant for, namely the decel popping, which also went away after this mod. Go figure.
Could be the spring, it seems to be much too strong for that small diaphragm. But i checked the one on an Keihin FCR i also have and it's just as strong as the one on the Mikuni.
Pilot Jet: 45
Pilot Air Jet: 65
Main Jet: 152
Post a pic of the carb...both sides please
what needle setting ?
