What is this thing on the rear axle nut?
I need ro tension the chain but how am I supposed to loosen this? Is it left hand thread? Thanks in advance. I wouldnt even be able to ride without this forum!1377912019056.jpg
You need to loosen the left side nut, use the numbers on each side of the rear wheel as a guide. The numbers on each side need to be the same to make sure the wheel is straight. Tighten until there is about an inch of up and down play in the chain. The bike also needs to be off the ground.
The Elbow on the bolt will move as you loosen the other side. It acts a catch and will move when you loosen the nut on the other side. It will catch on the upside of the swingarm.  the little nut on the snail is just to hold it still.
Edited by Bassjockey
Thanks guys got it all tensioned to spec. It seemed like the obvious way to go but the manual shows loosening the nut on the brake side, and does not have that little arm.
I don't know what someone did to your swingarm but where that pinch bolt with a nut on it is, should just be a pin for lining up the indentations on your snail adjuster. At least that is what has been on all of my xr650l's and xr600r that I have owned. All my bikes have been more current than yours though 1991 and up.
Just looked at the fiche and it does have bolts and nuts on both sides............I guess the newer models went to a pin to speed up wheel changes with less to loosen to remove the wheel.
Edited by tom00013
What's the differnce? The VIN comes up XR600R, but maybe the swingarm was changed at some point in its life?
That looks to be a drum brake rear wheel and an aluminum swingarm, so it might be an older XR600.  It wouldn't be a 650L or XL600.  Although the 1985 and 1986 I've seen didn't have that extra snail adjuster pinch bolt.
