'91-'94 kdx 250 ignition specs?
Hello,
I searched all over the net with no luck. I was wondering what the advertised advance specs where on the '91-'94 kdx 250, to see out of curiosity how they compared to the kx 250 ignition specs. I found info on the kdx 200/220's but nothing on the 250's.  I know all the kx 250 specs from '94 on. They list them in the shop manuals. For instance, the kdx 200 info I found showed 21 degrees advance, where as a '94 kx 250 has 14 degrees of advance (at 6k), quite a difference. If anyone knows the specs, I appreciate any info. Thanks.
Ok, after digging around for a while on the Kawasaki website, I found online viewable specs that show the '91-'94 kdx 250 advertised advance at 15 degrees at 6k. So not that drastically different than the kx advance that ranges from 11 to 14 over the years. The specs showed the kdx had a 38mm carb. I had thought the kdx 250's came with a smaller carb?
