Deceleration popping?
All of a sudden my bikes started popping when I let off the throttle? I have a 2011 RMZ 450 twin air air filter and cage Yosh RS 4 exhaust I have a JD Jetting power surge programmer have played with it to no avail. Running VP T4 fuel. I have done a search and really came up with nothing. JD's website says decel popping is usually caused by a exhaust leak which I can't see any leaks? Any ideas is much appreciated!
No fuel changes been running Vp T4 since new!
Suzuki's idea of a front number plate broke on me and that's where I have the JD tuner hooked up, so maybe a wire came loose ? The number plate broke jumping where it bolts to the triple clamp!
The tuner says its working, but I can't tell the colors! Suppose to have a green for idle pilot jet feature, but it looks yellow. Not very happy with the tuner!
Talked to a guy today that told me maybe I have a bad sensor. My bikes been hard to start cold lately and if I do get it to fire I can't touch the throttle or it will die when it's cold. Weird! I bought a Vortex ECU on e-bay and sent it out today to get re-programmed with the latest programs, so I threw on the stock ECU with the rich coupler because I run VP T-4 fuel (they say you don't have to re-jet, but I found that you have to richen the mixture one step) and a Yosh exhaust and the bike started second kick and the bike took throttle like it should.
 The last time I had the bike at the track it would pop when I got off the gas and it was running lean in the pilot circuit. I had a JD Jetting Tuner on it and I lost the colors to make adjustments in the pilot circuit (pilot circuit is green) and the adjustments I made didn't seem to work. JD Jetting's good told me to send it to them and they would take care of me.
 One of my questions is if I ran lean did I mess the plug up? Is that why the bike was giving me trouble? I put the Vortex on and It ran hot again (only ran it a couple laps) adjusted the trim to richen the mixture and bike ran good except for starting and throttle until warmed up. Anybody had any sensors fail?
