2013 YZ250...adding FMF Fatty/Shorty...changes to jetting?
I'm about to add a FMF fatty/shorty exhaust to my YZ250 and I'm wondering what changes I should make to the jetting.
Running 93 pump gas mixed 32:1.  I was thinking about bumping the main jet up one or two sizes.  Should this be good?
Please no recommendations on other pipes just jetting changes for new exhaust.
Print this, laminate it or uses clear packing tape, keep it in your tool box. It is everything you need to know.
And you said no other recommendations, but you need to read these
http://www.thumpertalk.com/topic/492565-yz250-squish-clearance/
http://www.thumpertalk.com/topic/584339-yz250-timing-thread/
Spanky's Jetting Guide:
A correctly jetted carb makes a tremendous difference in the torque, midrange pull, top-end pull, and over-rev of your engine. If you have never jetted your bike correctly, you will almost certainly gain some performance at some point in the bike's powerband.
A cleanly jetted pilot circuit can be the difference between having to clutch the bike out of a turn or not. The needle can make all the difference in the world for the power of the machine in most situations, as it controls the throttle range that most riders spend most of their time using.
A correctly sized main jet could mean the difference between being able to rev out high enough to not have to shift one more time at the end of the straight, or the power falling flat on top and requiring you to make that extra shift.
Are you fouling plugs? Many people will tell you all sorts of band-aid fixes, from running less oil, to running a hotter plug. Both are incorrect fixes for plug fouling. It's all in the jetting.
The only way to know what jetting changes you will need is by trial-and-error. No one can give you jetting specs, because every bike is different, every rider has a different style, and jetting is totally weather dependent. Unless the person telling you what jets to use is riding an identical bike, on the exact same track, at the same time, his recommendations are meaningless.
Jetting is fairly simple, and is a useful skill to learn if you ride a two-stroke and want it to perform at it's best.
It's very important that you start with the pilot circuit. The reason is simple. The pilot circuit affects the entire throttle range. When you are at full throttle, the main jet is the primary fuel metering device, but the pilot is still delivering fuel as well, adding to the total amount of fuel that your engine is receiving.
Before you start to rejet your bike, you need a clean air filter, a fresh plug (actually you need several plugs to do plug-chop tests for the main jet), and fresh fuel.
One important detail: Make sure the engine is in good mechanical condition. If your engine has a worn top-end, fix it first. Trying to jet a worn out engine is a waste of time. The same goes for reeds that don't seal properly, and a silencer that needs re-packing. Worn reeds will mimic rich jetting, and worn rings will mimic lean jetting.
Before you start the jet testing, Install a fresh plug. Set the float level to the proper specs, an incorrect float height will affect your jetting all across the throttle range.
Warm the bike completely, and shut it off.
As already stated, start with the pilot circuit. Turn the air screw all the way in, then turn it out 1.5 turns to start. Start the engine, and turn the idle screw in until you get a slightly fast idle, or hold the throttle just barely cracked, to keep the engine idleing. Turn the airscrew slowly in, and then out, until you find the point where the idle is fastest. Stop there. Do not open the screw any farther, or your throttle response will be flat and mushy, and the bike may even bog. This is only the starting point, we will still have to tune the air screw for the best response.
Now is the time to determine if you have the correct pilot installed in your carb. The air screw position determines this for you, making it very simple. If your air screw is less than 1 turn from closed, you need a larger pilot jet. If it is more than 2.5 turns from closed, you need a smaller pilot jet.
Once you have determined (and installed it if it's neccessary to change it) the correct pilot jet size, and tuned the air screw for the fastest idle, it's time to tune the air screw for the best throttle response. Again, make sure the bike is at full operating temperature. Set the idle back down (the bike should still idle, despite what you read in the Moto Tabloids), and ride the bike, using closed-to-1/4 throttle transitions. Turn the air screw slightly in either direction until you find the point that gives you the best response when cracking the throttle open. Most bikes are sensitive to changes as small as 1/8 of a turn.
The air screw is not a set-it-and-leave-it adjustment. You have to constantly re-adjust the air screw to compensate for changing outdoor temps and humidity. An air screw setting that is perfect in the cool morning air will likely be too rich in the heat of the mid-day.
Now, it's time to work on the needle. Mark the throttle grip at 1/4 and 3/4 openings. Ride the bike between these two marks. If the bike bogs for a second before responding to throttle, lower the clip (raising the needle) a notch at a time until the engine picks up smoothly. If the bike sputters or sounds rough when giving it throttle, raise the clip (lowering the needle) until it runs cleanly. There isn't really any way to test the needle other than by feel, but it's usually quite obvious when it's right or wrong.
Last is the main jet. The main jet affects from 1/2 to full throttle. The easiest way to test it is to do a throttle-chop test. With the bike fully warmed up, find a long straight, and install a fresh plug. Start the engine, and do a full-throttle run down the straight, through all gears. As soon as the bike tops out, pull the clutch in, and kill the engine, coasting to a stop. Remove the plug, and look deep down inside the threads, at the base of the insulator. If it is white or gray, the main is too lean. If it is dark brown or black, the main is too rich. The correct color is a medium-dark mocha brown or tan.
Once you have a little bit of experience with jetting changes, and you start to learn the difference in feel between "rich" and "lean", you'll begine to learn, just from the sound of the exhaust and the feel of the power, not only if the bike is running rich or lean, but even which one of the carb circuits is the culprit.
The slide is also a tuning variable for jetting, but slides are very expensive, and few bikes need different slides, so we won't go into that here.
Keep in mind, even though this article is intended primarily for two-strokes, four-strokes also need proper jetting to perform right, although they are not quite as fussy as their oil-burning cousins. The only real difference in the two is with the pilot circuit.
Two-strokes have an air screw that you screw in to make the jetting richer, ansd screw out to make the jetting leaner. Four-strokes, on the other hand, have a fuel adjustment screw that you screw in to make the jetting leaner, and out to make it richer.
Edited by adam8781
  • Like 2
Thanks for the info and I know every bike is different but generally speaking what have most people had to do jetting wise after adding a new exhaust system?
I felt that my bike was leaner with the fatty on than oem. I put my pilot up to 52 and main to 182. I know that is way to rich for most people, but WOT on the track it doesn't feel like my bike is going to explode.
  • Like 2
I have a gnarly on my 2013 yz250 bike runs mint had a jet kit put in ill send the settongs tomorrow it runs so nice. I run my mixture at 40:1.
I have the Factory Fatty and Titanium-2 silencer on my 2006.  I think the Factory pipe is the same as the regular Fatty, just unplated and also pretty sure the Titanium-2 is the same dimensions and tuning as the Shorty muffler.
I have the stock 50 pilot and 178 main.  Only change I made was the needle.  I put in the N3CJ which is 1/2 clip position leaner than the stock N3EJ (your bike has slightly richer N3EW).
I tried going both directions on the pilot, main, clip, and needle diameter and that's where I ended up.  Bike is crisp and rips. (I ride MX only, no trails or tight stuff)
I run 100 octane unbranded pump "race gas" and Maxima Super-M at 32:1 with no splooge.
Try keeping the jetting stock at first with the new pipe and go from there.  Make 1 small change at a time and see what the effect is.  Decide better or worse and go from there.
Thanks for all of the tips.
I have to adjust my float height.  I had a stuck needle valve so when I cleaned that I adjusted the float height because it was slightly out of spec as well.  I think I may have adjusted it too much so I'm going to put it in the middle of recommend specs.   I just figured since I had the carb out I would try and predict jetting changes needed.  I was thinking of trying a 180 main first but I might just run it with the stock jetting when I install the pipe and see how it runs.
The only thing is I have no where to ride my bike to test it where I live and I don't like doing a lot of work out on the trails so I was hoping to predict what needs to be done.
A good start point would be to call either FMF or Zip Ty Racing...they can give you good information.
I'm not sure if its correct, but I heard the factory fatty is made of thinner metal
I
I put PC platinum II and 304i know its not an FMF but I was running all stock with 32:1 castor but now with the Pc and amsoil 50:1 runs like a raped ape!
Wow...I posted this a while ago.  Anyway.  Ended up putting on pipe/silencer combo and made no changes to the jetting and it runs great.
