anybody use a mikuni non-pumper flatside on an lc4
i ask this question because of all the complaining about the bst carb used in most lc4 based ktm's
i am not asking about kiehnen fcr or mikuni "pumpers"
just the basic mikuni cv flatside carb vs a mikuni cv bst carb
mainly the three on the right
 they are cv carb and not pumpers so they are as good with altitude as a bst without the issues you get from running over rough terrian
i am not refering to the kiehnin fcr pumper carb which many people want for it's pull from the lower rpm's
yes they look/are what is normally used on twostrokes
does anyone know of someone that has run one on some form of lc4 based moto
i did use one on my xr600 and it worked better than the stock carb up until i put in the full on fcr pumper
Grump:  I would suspect that the solution use on your XR would be identical to/for the LC4.
just wondering if there is any jetting info out there
i will check in with motolab on tues
rode out at carnegie in ca and as rough as that place can be with gnarly uphill acceleration bumps no rough running
