Pilot jet
Need to clean/replace on my 08' beta(rfs)
Do I need to pull carb?
If so is there a trick, not a lot of room.
no you dont, just loose the front and rear clamp, rotate carb, take the plug and you can take access to the pilot jet
no
You might think about pulling the carb and replace the float needle while your at it. It's a commonly overlooked part that should to be replaced periodically…..
