stator
new to forums... first time rider!!! i need hel ... 78 kawasaki kl 250 ... changed shift shaft now no spark WHY?? can i test the stator by kick start?? also... how can i bypass the kill swtch ?? PLEASE HELP... THNX N ADVANCE FOR ANY AND ALL RESPONSES
The stator I don't know about, the kill switch on the other hand is easy. All you gatta do it take the positive and negative and connect them together.
Check your fuses and other connections, look for shorted wires rubbing on the frame.  Stators don't usually just die, they go slowly.
Edited by gsa102
