Squashed oil vapour recover tank line
Installed the mcct yesterday and notice this line was squished and kinked, is it ok to be left as is?
Thanks
Edited by Noggin
You could run it as is. You are risking performance bit the bike will run as is.
I would try rotating both ends of the hose, slightly either way to see if the hose unkinks.
Edited by bmwpowere36m3
It is a preformed hose, and currently twisted... Rotate one end or the other will the line is not twisted, all will be fine.
Thanks for the replies, I checked to see if it was twisted and it appears to just be squished by the tank. I did try to twist it but it just deforms it, so this is the fix I came up with.
ImageUploadedByThumper Talk1378199285.987057.jpgImageUploadedByThumper Talk1378199306.617145.jpg
