what is this hole on the bottom of my cases (04 cr250)
Is this supposed to be there? It looks like it is..the reason I ask is the gasket that seals my cases is going bad and leaking considerable amounts of transmission fluid and I saw some dripping from here.
If its pretty much under the crank, its just a drain for an empty chamber thats seperate from everything. The crank area and tranny is seperate from that spot. If I recall correctly, there might be one towards the front of the cases. If so, its a weep hole I assume incase the center o ring between the cases for the water passage would happen to leak.
good to know, thanks
