Which one is better
I have a blaster and I want to get a trx 400 instead. Should I stick with the blaster or get the trx
400ex, better quad all around.
stick with the blaster, its fun, its cheap, and easy to through it round. u can rebuild a blaster top end for a couple hundred. to rebuild a 400ex top end it will cost u bout 500. valves and stuff r expensive
A "top end rebuild" on a 4t is usually just a piston and rings....If you cook the cylinder it's just another reason to go with a bore.
You really have to be doing something wrong to cook the cylinder head...I've personally never done that before and I ride my bikes like I stole them.
400ex has been around for a long time and their bulletproof one of the best made engines ever, blaster are good to learn on that's about it... get a 400ex make sure its got oil and it'll last forever
when was the 400ex first made? the blaster was first introduced in 1987 then ended because of stupid ass tree huggers in 2006. parts are still easy to find and its cheap, u can buy  fmf pipe for a blaster for bout 300 how much is a fmf for a 400 ex? probly close to 500. parts for 2 strokes are cheaper, and 2 strokes are more fun to ride than 4 strokes.  4ts are to heavy to thrown and have fun in a yard the blaster u could have fun in a yard thats only 100 square foot
I'm looking at a trx 400ex with a 440 kit in it right now
careful with the 440 kits seen a lot of headgasket problems with those
yeah thanks it's a quick cheap fix though
Shouldn't have to worry about the head gasket if you ride it correctly. If you sit there and do burnouts and keep it on rev limiter that will be the first thing to go...But what bike doesn't have problems when you beat on it like that?
I had my 440 (also was a 99' :ride: ) for 4 years and I only blew one head gasket towards the end of the ownership.
I'm actually going to look at a 99' 400ex with a 440 big bore kit in it tonight
