what cams to get ?
been looking for a set of good used E cams and can't find any thing
so thinking about buying a new set
the hot cams stage 1 or stage 2's whitch is the better ones ?
i ride mostly street and a little dirt 90/10%
i got a friend who has a set of used web cam cams and was wondering how they compare to the E cams stg 1 2 hot cams?
and yes is any of you are wondering I'm going to be doing a carb also
Here are the specs for some of the cams available , sorry I dont have the specs on the web cams , greg
S&SM Int. .334 lift 227 dur Exh. .323 lift 243 dur
E&K Int. .351 lift 227 dur Exh. .366 lift 243 dur
yosh Int. .354 lift 236 dur Exh. .366 lift 242 dur
HC stage 1 (new) Int. .358 lift 238 dur Exh. .358 lift 238 dur
HC stage 2(was stage 1) Int. .377 lift 243 dur Exh. .377 lift 243 dur
HC new stage 2 (was st1) will do fine for your riding and mods.
E cams are almost the same as HC2 (have fixed cam gears, so no extra degreeing possible, 99.5% does never re-degree though)
HC very old style stage 2 is wilder (more lift and dur) but not recomended with stock valves and springs.
Some ppl use them no problems, but in my opinion its too much.
Also you do not need cams that wild without Bigbore.
The do not come with auto-decomp. (not a big deal when battery is fine)
HC new style stage 1 i don't know.
Webcams: they have many types.
Also real good quality product so good contender for buying used.
You can visually inspect the used cams for damage (or send a pic here).
Most of the webcams are really wild, absoluteley needing better springs like the HC very old stage 2.
But there are milder webcams out there.
You will not be able to see the difference in dur/lift with the eye.
Does the friend have specs or a model nr?
Every once in a while used old style HC1's show up on the TT classifieds, local forum or ebay BTW.
Edited by jhondius
I can dig up the webcam specs if you have a part number
That would be sweet
So there are 3 generations of HC's..
current
old
very old
what do the differences in lift and duration do? I think that might be where my difference is. I probably have a set of new and a set of old. The new cams bike runs smoother...
better to go with the E or the hotcams stg 2?
found a pair of E cams for $170 worth it?
How many miles on them ?
The auto decomp could be worn ,... Just sayin'
No clue
Will ask
Planning on doing a big bore in the future
So I'm guessing ill do the stage 2 hot cams
Yeah .. Weigh up the cost of new HC cams compared to any used E cams . The problem of buying used E cams is the cond of the auto decomp . Some have been known to cause BIG problems . Just a possibility of failure really . Unless you know the E cams are low mile , or you can remove the auto decomp altogether .
I put the old stage 1 HotCams in me bike,  and man,  made a real nice difference,   really happy with them.
