Bike Won't Start, I Believe Its The Coil.
Hey there pretty new to the seen.
I recently picked up a chinese clone of the Honda CRF70 I believe. Anyway I test drove it before I got it ran great, then got it home and took it out for another spin samething it worked great. I left for the night after that then today when I went to ride it she wouldn't start. Upon further inspection I noticed there was no spark and the spark plug was all covered in black stuff. So off to the store I got pick up a new plug try that samething no spark.
I did a compression test and everything seems to fine. So this leads me to believe its something electrical my guess is either the Iginiton Coil I always hear about them going on these little china clones and my second thought if not that, would be the CDI?
Just looking for your guys input on the whole situation.
If I did end up having to replace the CDI box would I have to replace the whole wiring harness?    Usually theres like a 5 pin molex connector or something, however on this bike it seems the wires going directly into the CDI, so would I need a whole new wire set as well if replacing the CDI ?  <--- Im more stuck on this then anything.
Thanks in advance to anyone who sheds some light on this !
Check out tboltusa sight. I found this
Home
TBolt USA New Owner Info
Pit Bike Wiring Info
Basic Pit Bike Wiring
Wiring With Lights
Wiring With Lights
Japan Inner Rotor Kit
China Inner Rotor Wiring
Lifan Outer Rotor Wiring (Daytona Style)
155cc or 155Z wiring
Wires you likely wont need
Testing Electrical Systems & components
How to Remove & Replace a Broken stator
Pit bike engine wiring and Chassis wiring systems
Honda XR/CRF50 & 70 Wiring
General Motorcycle Maintenance
Identifying Parts, Bikes, and Engines
General Motorcycle Troubleshooting
Pit Bike Installation Info
How Things Work
Parts Diagrams and Breakdowns
Testing Electrical Systems & components - TBolt USA Tech Database!
Testing seperate Electrical systems:
Make sure all electrical connections are tight and you have a solid ground from the engine to the frame.
Disconnect Kill button (will run/spark without it)
The coil is actually three parts
coil
wire
cap
all three screw together like a wood screw , clockwise
Make sure you have a good spark plug (Pit bikes take the same plug as CRF50 & KLX110)
Testing seperate Electrical Components
 STATOR:
(Once you have the ignition cover off) Visual test:  Inspect  the coil bar , if you see any bulges or discoloration its likley worn out
Voltage Meter will be set on AC for testing output
The stator should have 80-100VAC (usually black/red)
Set meter to OHMs
OPEN circuit or infinity OHMs is bad
COIL:
Set meter to OHMs
Awesome thanks man, I knew about some sites for parts. Didn't know about them tho and they seem to have alot of information there as well besides just selling the parts.
If I could i'd give +Rep.
Well finally got it going turns out it wasn't the stator, coil or cdi. It was just shady wiring there weren't making the connections they were suppose to and the kill switch was wired completely wrong. Who ever had the bike before me thought they knew what they were doing but didn't. After that the carb was removed for cleaning and it was found that the throttle needle was bent in a ushape almost. Whoever had it before me just rode it hard and put it away wet.
Luckily a buddy at my dads work is really into the whole motocross dirt bike thing and had her fixed up and running mint in 6 or so hours.
So its up and running now just need to get an air filter and im currently looking at Nitro kits.
