What's the most common front tyre size for mx?
Reason I ask is because I thought there was only one size but yesterday I came across a bike with a 80/100 21.
That doesn't seem to be very common here in uk.
Your thoughts please
Which is uncommon to you?
The 80/100 or the 21"?
The 80/100
Mine is a 90/90/21
Cheers
Indeed. The 90 got popular for a couple years and one came stock on a kx450 I had. I remember because I put an 80/100-21 on it before it left the garage.
I see both 80/100-21 and 90/100-21 regularly. In fact, it seems like every tire I've purchased had an option for both on Rocky Mountain. I see more 80/100's on actual bikes though. I thought the 90 was good in the sand, and stable overall, but I thought that the 90 tire tried to climb out of ruts more and I did not like that. Of course, it's hard to say without being able to switch back and forth. Plus, I believe different companies size their tires differently, despite what it says on the side.
Wow. Loads of info, What I thought was the odd one is quite common then, I've just put a new front on mine the same as was already on there because i never even new there was options.
Cheers
I have changed from maxxis to Michelin though, haven't ridden it yet to see if any difference
