Header temp?
Anyone ever stick a thermometer on the header pipe after a ride to see the temps generated? Or the whole system for that matter?
internally, guess 1250f a few inches away from the head
In other words don't touch 'cause it's gall darn mother freaking what in the sam hell was I thinking hot!!!!   To put it nicely that is...  :rolleyes:
  • Like 2
OK, but no one knows what temp!
That all depends on a bunch of things like load, engine temp, speed, rpm, air temp and so on...  Figure between -35 - 1100 degrees on the outside...  The inside temp is what counts.
Im thinking of coating my system, just wanted a ball park figure to know how hot it got to see if the material I have will work or not! I know some guys do weird stuff like take a temp reading, maybe, but yes, I know its hot, i know it burns holes in jeans and all the other backwoods , homily based descriptions!
Guess i'll just go buy a thermometer and figure it out, BUT, if anyone does by chance get a reading, someway, somehow, let me know!  Yes, it is lickin' lizard hot!
http://www.jet-hot.com/coatings/
i know you cant use it on a header but has anyone ever seen the PRO-CIRCUIT stick on "tape type" thermometer??? its like what you would use on your kids forhead... i think its $20 on ebay...
1200 degrees Farenheight would be max temp for the L. Jet-Hot is a great product, but you will need to find a metal coating company to buy it and apply/cure for you. I am getting the Jet-Hot 2000 put on my diesel truck exhaust manifolds.
Are you going to get your FMF header and muffler coated?
Edited by dkappelm
I got a decent 2nd hand Big Gun, but just wanted it to be different, the coating I have is "guaranteed" to 800, after that they can't guarantee no discoloration or?
So that is why I was curious as to how hot it "actually got in action, like I said, if after a ride someone would just stick a needle thermometer on the pipe to see what it registered, gives me an idea if a waste of time and money!
800 F probably not enough. Other thing is, some of the high heat paints like VHF affected by petrol. ...but they are good for a year or so, at least.
I was considering coating my mega bomb header as well so would be curious to know the temp if anyone ends up taking a measurement. I'm also not sure how the coating will affect performance. The header is from BDSB so it already has an internal ceramic coating. Thoughts?
