2stroke or 4 stroke
How can I know if my pitbike is a 2 stroke or 4 stroke
Do you have to mix the gas?
thank goodness I thought this was going to be another 2t vs 4t thread
No I don't have to mix the gas
then it's a 2 stroke. make sure to check your exhaust bearings and blinker fluid.
I know Im also tire of looking at those
Thanks
Does it have fuel injection or a carburator??
Good joke one of the best I ever heard
Carburetor
Does it have dual exhaust usually dual exhaust means a 2 stroke.
Since no one here wants to give you a real answer, they're a real bunch of comedians  :moon:
The easiest way to tell is look at the exhaust pipe.
2 strokes have expansion chambers, big head pipes   http://en.wikipedia.org/wiki/Expansion_chamber
4 strokes have small header pipes  http://www.google.com/imgres?imgurl=http://ktmdirtquestions.com/wp-content/uploads/2011/08/head-guard.jpg&imgrefurl=http://ktmdirtquestions.com/review-ricochett-4-stroke-header-pipe-guard/&h=280&w=464&sz=25&tbnid=TYYlvVseZrhUnM:&tbnh=90&tbnw=149&zoom=1&usg=__-3AcqnD7hOY086G_lv4lqZoLvkQ=&docid=aYhGWdpkntxqaM&sa=X&ei=wLcmUqnPEMTAigL9voGQAg&ved=0CFwQ9QEwBw&dur=1779
More than likely your pit bike is a 4 stroke.
seriously? ? ?
Everyone excep the one guy is being..... scumbags. Look at the exaust pipe, like he said. Pit bikes are pretty much always 4 strokes, and I honestly dont even think a two stroke would make it one ride without the 2 stroke oil. Since I started I might as well explain the difference if you care to know. 2 strokes do what four strokes do in two revaloutions opposed to four. They sound a lot different, a higher pitched noise with smoke coming out the exaust. Thay have this wicked thing called a powerband, which is basicly where all the power of the bike is hidden in high rpms. They tend to be lighter, and have better flickability. The 4 strokes moter is much more complex consisting of camshafts etc. etc. Making 2 strokes much easier and cheaper to work on. I could go on and on about differences but make sure you do routine oil changes, air filter cleanings and much more. Hope you took the time to read this and good luck with your pitbike there tons of fun.
Its a 4 stroke and
Thank u the only serious person on this
I asked a perfectly reasonable question.
I think your question....was kinda what he was trying to figure out....
Me to
Post up a pic of your bike sir ill try to give you some serious info
