yz250f front brake fluid resevoir
he all
Just bought a yz250f 09. When wanting to remove the front brake fluid resevoir i dound the cross head bolts where ruined. Does antbody know what size these are, im pressuming they are metric. Also whats the best way to remove the ruined ones, will it be drill and easy out.
Tar
If there is absolutely nothing left for a screwdriver to grab onto, you can drill off the head of the screw, remove the cover, and using Vice Grips, grab the remaining portion and un-screw.
thanks for that. Does any one what size they are, ive found loads of part list but none list the size
