shock linkage help !
just ordered a pc linkage arm for my kxf250,   because of the different length does this mean i have to run different sag?  At the moment im at 90mm sag . does this need to be the same with the pc linkage or does it have to change?
any help would be great.. thanks
You most likely will need to measure your sag and if the linkage didnt come with a specific sag limit i would go with what you have 90-100mm
Edited by diegoo.jayjay
Hi there, I asked exactly the same question when I fitted my pc linkage to my kx 250.
I contacted pro circuit and they said to run the same sag as normal, just fit the arm, check the sag and adjust as normal.
That was good enough for me as it was straight from the horses mouth.
Cheers!
Cheers!
great , cheers.     so can u feel a difference with the pc link.  theres alot of debate over weather u can or cant tell a difference ... whats your opinion?
  ive got A Kit kyb suspenion and im at the point where im gunna spend a while trying to get it set up perfectly for me. ( im hoping the pc link will help me even more )
