2003 CR 125 coolant problem
Every time I fill my coolant and start my bike it starts to piss coolant not sure if this is normal
Not normal.
Most likely something with the headgasket or the waterpump.
Would a blown head gasket cause a loss of power? Because the bike feels just as powerful as before
pull the cap off.  if you see bubbles when the bike run and foams up the fluid, you have a head gasket leak
Ok I'll try that also for re-torquing the head bolts what weight should I set the wrench at?
get the head re surfaced and get a new head gasket, my 125 was doing this a month ago and it had a warped head.
It was just the gasket
