My 97 dr200 did not come with kick starter i want to put one on it
My friend said that i can just slide the shaft into the hole and just like that i have a kick starter
My father said that i would have to split the crankcase to put one in
Please help me if you can
I've added them to both my drz400 and my dr350.in both cases it only required draining the oil and coolant(drz only), followed by removing the side cover and clutch assembly. I could be wrong but since the sidecover is already prepped for the install you should only need the kickstarter, complete kickstarter shaft and ratchet gears, as well as the idler gears and bushing. If you do your homework the whole project shouldn't take more than an hour and a half. Hears a link to the install on the drz which may be of some help.
http://mr-cob.smugmug.com/gallery/136763#!i=4997029&k=CgVqznJ
If you refer to the parts fiche for your model you should be able to put together a good pan of action.
