Yamaha 2004 YZ250F REBUILD top end and valve train HELP AND QUESTIONS
So the other day I pulled the old 2004 YZ250F out after moving to Colorado from Hawaii so...
the 1st problem started with ALTITUDE over a 6000 ft difference. I knew i needed jets so i went to the local shop here and they hooked me up.
the 2nd problem after i got it all together, and rode around seemed flat at the top end and i started to get cherry pipes.
so my dad said valves, you should check to see if its getting enough air.
so i pulled it apart myself and start getting my gaps for re-shimming it.
the 3rd problem comes along all the valves need adjustment.
left exhaust was 0.15mm
right exhaust was 0.15mm
left intake was 0.00mm        (could not get a 0.04mm is smallest feeler gauge i have)
center intake was 0.00mm
right intake was 0.09
specifications for the maintenance manual
exhaust is 0.17mm to 0.22mm
intake spec is 0.10mm to 0.15mm
so i pull the center intake shim to see what size i need to put in and its 120mm, the smallest shim
so im guessing i need new valves???
THIS IS WHERE I NEED YOUR HELP!!!!!!!
????????do i need to get all new valve assembly ( valve, seals, seats, springs, and retainers?)
or just some parts
???????what kind of head work does this need before i install new valves??? (valve seat cutting)
what shop is good?
????????steel vs titanium?
??????? will any valve work for a yz250f or do i need to get a measurement?
since I am going to rebuild the valve train, im going to toss a new ring and piston in also.
?????? brands should i use for ring and piston ?
should i send my cylinder off also?
thanks for the help in advance
photo.JPGimage (1).jpegimage (3).jpegimage (2).jpegimage (5).jpegimage (4).jpeg
dude ur in the wrong forum. head over to the dirtbike forum and u could probly get alittle better.
Yeah I know it's my first time posting on this site but I wanted to leave it up here because a four stroke motor is the same on dirtbike or four wheeler
Ya it is, but being the dirtbike motor the guys over on the dirtbike side could probly give more indepth ideas
or just some parts
what shop is good?
photo.JPG image (1).jpeg image (3).jpeg image (2).jpeg image (5).jpeg image (4).jpeg
send this thread to us dirtbike guys. You will get your answers. Post in the make/model specific thread under Yamaha yz250f
