Honda XL175 crankcase compatibility
it does look the same . Get yours off and check the inside mounts for the stator and if they are the same , then its 20 bucks well spent , greg
Yep. Went ahead an ordered the crankcase cover and it fit just fine. Seems the motor is the same from 1973 to 1978. Good to know...
1978 xl175 no spark. I
need help?
Do you have the service manual?  If so you can use this video and start testing your ignition system.  That is as long as you are sure your kill switch is not grounding the ignition out.
